TPS3813K33-EP: RESET! Window exceeds spec value at cold temperatures.
Part Number: TPS3813K33-EP
PN TPS3813K33MDBVREP is used in an application where it is tested at -55C.  Some parts are causing failures, where the processor is not receiving a RESET! signal after the TDI signal goes silent for over 300ms.  Troubleshooting data indicates the RESET! pulse window grows approx 35ms between ambient temperature and -55C.  This appears to be enough of a change to push the RESET! signal out of spec.
