TPS1H100-Q1: If TPS1H100 has about 10.2MHz switch frequency internal?
Part Number: TPS1H100-Q1
Hi, Team:
We DIN TPS1H100-Q1 in Infotainment project but when run EMC test with no load but TPS1H100-Q1 enabled, we find there is a 10.2MHz RE spike close to TPS1H100-Q1. We checked, if disable the switch, the spike will disappear.
Can you help to check and advise if  TPS1H100-Q1 will have internal 10.2MHz switching? If possible way to reduce it?
