TPS54335A: land pattern changed, whre datasheet rev# is same
Part Number: TPS54335A
Hello
My customer is using TPS54335A for their product and intends to use for their new board also.
However, customer had found the land pattern had beed changed :where data sheet rev. us same.
Q1
Is there NO concern with using the land pattern which follows the old datasheet? ( pdf attached)
Q2
What is the reason why change the land pattern ?
Do you recommend to follow the land pattern for latest datasheet?
Please kindly advise.
Best Regards
*latest ( which found in TI website Now!)
SLVSCD5D –NOVEMBER 2014–REVISED FEBRUARY 2016
Land pattern ; page 55/57 DRC0010J VSON - 1 mm max height  : www.ti.com/.../tps54335a.pdf
*old ( attached: which customer has.  )
SLVSCD5D –NOVEMBER 2014–REVISED FEBRUARY 2016 ( same number)
Land pattern; page 51/53 DRC(S-PVSON-N10)
===> customer had followed this land pattern for their production.
slvscd5d.pdf
