I would like to know what happens if 5 volts is present ( in our case from a usb port ) on the 2 out pins of this device. EN will be set low, but what if the out pin(s) are at 5 volts before power on the IN pins is on. can the out pins back feed the in pins? the scenario is a usb cable is attached to our product and the product is not powered on.
