TPS2663: Pins 19, 24, and /SHDN
Part Number: TPS2663
Other Parts Discussed in Thread: TPS1663,
I have 2 questions:
1) On the VQFN package, can pins 19 and 24 be connected to OUT and IN, respectively (just like the TPS1663), even through they are labeled NC?
2) Would you recommend leaving the /SHDN pin floating (pulled up internally) if the application does not require shutdown mode (is it robust enough)?
Thank you
