BQ27220: Error: discharge data points less than 10, N=2 in file roomtemp_highrate.csv
Part Number: BQ27220
Hi All,
I have tried several times, but still can't get the correct GPC report. I received this err below.
Thank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
The following errors were reported by the calculation engine:
Please see the Gauging Parameter Calculator for information about the file format and the procedure for creating the input zip file. Should you want to resubmit or need assistance with the Gauging Parameter Calculator, please reference the sites below:
• Go to Gauging Parameter Calculator to re-submit.
• Visit TI E2E™ Community on Battery Fuel Gauges or the Gauging Parameter Calculator.
• TI Battery Management Homepage
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.
However, this error does not make any sense as my csv files have at least 1000 individual discharge points. Can someone please provide the specific meaning of that error and how it can be corrected?
here is my zip file.
out5.zip
Sincerely,
Winkey.
