TPS56637: RTM
Part Number: TPS56637
Hi ,
Is it possible to have more detailed information on the RTM date of the TPS56637 component? (ie the beginning of June or the end of June ..)
  • Former Member
    0 Former Member
    Hi Giuseppe,
    The RTM date of TPS56637 is around Oct/9th/2019, and it can be sampled at around June/7th/2019.
    We now have silicon samples available, which is functionally and spec-wise the same level as the final silicon.
    Please let me know if anything else I can help. Thanks.
    Bruce
  • Hi Bruce, thanks for this info, I have another question about it.
    Considering that I will probably need 30/40 samples for about the beginning of June, to whom should I order these samples and how long is the delivery time? Same questions for devices released after October 9th
    Best regards
    Giuseppe
  • Former Member
    0 Former Member in reply to giuseppe ferorelli
    Hi Giuseppe,
    Final silicon samples can be available at around June/7th. And if you can accept the present silicon, please submit request through www.ti.com/.../TPS56637. And then our team can handle the delivery to you. It will take 5-9 days for the delivery to reach you.
    And you can directly order TPS56637 through TI-Store or distributor once it RTM released. 5-9 days are needed for the delivery too if the stock is enough.
    BRs,
    Bruce
