We have questions about TPS22810.
Question 1.
Datasheet p.14 9.3.2.2 Internal QOD Considerations,
When using only the internal RPD to discharge a load, the total capacitive load must not exceed 200 uF.
Otherwise, an external resistor, REXT, must be used to ensure the amount of current flowing through RPD is properly limited and the maximum TJ is not exceeded.
Do you know the formula that show the relationship between recommended value of external resistor and load capacitance?
Please tell us the recommended value of external resistance if we don't understand the load capacity.
For example, it is over --Ω.
Question 2.
Please tell us the recommended maximum capacitance value of CT.
Takahiro Nishizawa
