TPS2511: May we have part can replace S1F77310M0A?
Part Number: TPS2511
Other Parts Discussed in Thread: TPS2546
Hi Sir
                                              Bogey
  • Hello Bogey,
    No I do not believe we have a direct replacement for this part. You can use something like the TPS2546 which is a USB controller, having the ability to charge a usb port, and if you change the charging mode of the TPS2546, you can disconnect the D+/D- lines from a connected host.
