UCC28740: about Transformer for PMP30435
Guru 11170 points
Part Number: UCC28740
Other Parts Discussed in Thread: PMP30435
Hello E2E,
Please let me know about PMP30435.
I tried calculation about transformer using sluc487. Calculated result is Lp=10mH over. The calculation results and the specifications of the TID transformer do not match.
Can I have a design calculation document for transformer of PMP30435?
ACGUY
  • Hello Acguy,
    The design calculator was used to design the EVM and the calculations should match that design. However, there is not only one way to design a flyback and the design constraints maybe a little different.
    I have forwarded this inquiry to the designer of the PMP30435 so they can share how the transformer turns ratio was calculated.
    Mike
  • Hi Mike,
    Thank you for your cooperation. If you had any update, please let me know.
    ACGUY
  • Hello AC Guy,
    I thought, I had assigned this post too f-mueller@ti.com, so he could answer your question regarding the transformer. Mr Mueller is the designer of this EVM an assigned the post too him so he can answer it for you.
    Mike
