Other Parts Discussed in Thread: GPCCEDV
Will the same CEDV coefficients obtained from TI GPC Tool for 4S8P pack with 3.2V per cell and 25.6 Ah with bq4050 work for a 4S6P pack with 3.2V per cell and 19.2 Ah.?
Or is it required to run the Temperature Chamber tests again and upload to GPC tool for 4S6P pack ?
And are the CEDV coffecients only dependent on no. of cells in series or also on the no. of cells in parallel?
Also in the GPC report sent from TI it is mentioned -(Accuracy Error: Deviation is so high that it is most likely due to anomaly in the data) but also provided with CEDV co-efficients ,so how likely and accurate are the CEDV coefficients provided from GPC tool considering the deviation.
