CCS/UCD3138A64OEVM-662: Program does not run when I disconnect the target power source and reconnect it.
Part Number: UCD3138A64OEVM-662
Other Parts Discussed in Thread: UCD3138A64
I have UCD3138A64 module with me, every time before i burn the code using CCS I clear the flash memory and than load the desired code, during burning the code it shows writing in flash at certain range of address and Performing Flash Program on certain memory range. But when i disconnect the power source and reconnect it , the program does not run.
Does this imply that the code is present in the RAM and not in the flash ?
P.S I even used the sample codes provided in training labs but still i get the same error. Please reply fast .
