UCC28070: ucc28070
Part Number: UCC28070
this violate the requirement that the VINAC divider ratio be the same as the VSENSE divider ratio
This is as per page 19 of the UCC28070 datasheet
  • Hello Andrea,
    It is recommended that the divider ratio on VINAC and VSENSE be equal in order to maximise the accuracy of the current synthesizer.
    It is not a requirement that the ratios be the same. It is just a recommendation and perhaps violate is not quite the appropriate term .
    Thank you for your contribution
    John
  • Thanks John for the quick response. We are planning a high power multiphase PFC with 2 UCC28070. We would like to get a variable output by changing the reference voltage of the external error amplifier. What do you think?
