TPS92692: Open LED Fault
Part Number: TPS92692
How do i detect open circuit in ci tps92692
  • Hi Josnei,
    By setting the Over-Voltage protection to be about 3-5V higher than what your LED load requirement is this is how it detects open circuit. If you do not have a load the output voltage will ramp up but since there is no current feedback (open circuit), the voltage will continue to rise until it hit the over-voltage setting then it would shut down.
    Please read section 8.3.14 for this.
    Thanks Tuan
