Dear mr, mrs,
I want to use the LP8863 but need also a (little) higher output voltage then the 47V. It should be 53V.
Is it possible to use an external power supply at 53V and set the LED_EXT_SUPPLY bit?
As the application is for a multiple led control with all kind off different led configurations this IC is right for 90% of the applications.
