Other Parts Discussed in Thread: BQ34Z100, BQSTUDIO, GPCCHEM, GPCRA0
Designing a 22000mAh battery pack with bq34z100-g1
Expect up to 110A sustained currents as this is a LiPo pack for heavy octocoptors
Design procedure:
Designed, fabricated, and assembled PCB
Updated firmware to bq34z100_G1_v0_16_build_17.srec
Updated bqstudio with the latest chemistry options
Set the appropriate flash defaults in the bq fuel gauging chip for basic functionality
Determined a chemistry match by following the insructions for the GPCCHEM tool
Followed the charge, rest, C/10 discharge profile
Successfully obtained a sutiable ChemID of 1530 with Max DOD error of 1.63% and Max R deviation ratio 0.8
Instrumentation was performed with a Yokogawa WT310 power meter for optimal accuracy
Re-flashed bq part with stock firmware
Updated chemistry of bq part to 1530
Updated flash parameters of bq part with a current scaling factor of 4:
Taper current = 110mA (scaling factor of 4 so this equates to 440mA)
Min Taper Capacity = 6mAh (scaling factor of 4 so this equates to 24mA)
Cell Taper Voltage = 40mV
FC Set% = -1
CC Threshold = 5500mAh (scaling factor of 4 so this equates to 22000mA)
Design Capacity = 5500mAh (scaling factor of 4 so this equates to 22000mA)
Design Energy = 20159mWh ([21793; single cell capacity] / [4; scaling factor] x 3.7V)
Design Energy Scale = 1 (can’t scale up because max value in register is 32767)
VOLSEL = 1
RMFCC = 1
Number of series cell = 6
Cell terminate voltage = 3000mV
Dsg Current Threshold = 25mA (scaling factor of 4 so this equates to 100mA)
Chg Current Threshold = 25mA (scaling factor of 4 so this equates to 100mA)
Quit Current = 10mA (scaling factor of 4 so this equates to 40mA)
Qmax Cell 0 = 5434 (scaling factor of 4 so this equates to 21736mAh)
Calibrated voltage
Calibrated current with a scaling factor of 4
Performed a successful learning cycle by following the instructions
Started with a fully discharged and rested battery
Charged at C/2 until taper; FC was asserted and charging was stopped;
Relaxed 2hrs
DSG at C/10 until empty
Relaxed 5 hrs
Achieved learning status of 0x06
Ra tables updated appropriately
Created golden image
Saved .gg.csv file from above; set update status to 0x02, cycle counts to zero, lifetimes to defaults
A clean/default srec imported on the device
Chemistry updated on the device
Imported .gg.csv file to device
Calibrated voltage
Saved this .srec as a golden image
Re-programmed bq part with this golden image, enabled IT
Validation:
See if the bq part updates the Ra tables with a C/5 DSG rate
Started with an empty, rested pack
Charged at C/2 until FC asserted
- Relaxed 2hrs
DSG at a C/5 rate and watch Ra tables
PROBLEMS:
The RUP_DIS flag asserted during DSG at 84% SOC for some reason and remained asserted down to 0%
Note: After I noticed this I did end up bumping the DSG rate up to 1.3C for a few minutes to just empty the battery and then decided to resume at C/5 just to complete the test. Nonetheless the RUP_DIS flag asserted before this happened.
Subsequent attempts with this golden image have produced the same problem. I also tried to use the GPCRA0 tool (not including this data right now) to see if I could get better pre-programmed Ra coefficients but the problem persists.
I would like the bq part to work with 5C discharge rates but can't get it to behave with even C/5 rates right now. What would be the next steps to getting it to perform appropriately in this usage scenario?
Included are the golden .srec and the .gg.csv for the bq part before performing the test and log data from the above test.
/cfs-file/__key/communityserver-discussions-components-files/196/TestFiles.zip
