TPS62148: MIN/MAX value for negative current limit
Genius 17325 points
Part Number: TPS62148
Hello
 I need min and max value of the below parameter. Is it available?
Also what happens if this negative current limit occurs?
Oba
  • Hi Oba,
    We do not specify the Minimum and maximum value for this spec because it is not tested for min max.
    The customer should always avoid high negative current values because if a high negative current occurs, a current runaway might happen.
    Omar
