TPS54302:How to use TPS54302 En pin
Part Number: TPS54302
What does the following sentence mean? Can't I/O port be used directly to control EN Pin?
“The EN pin has an internal pullup-current source which allows the user to float the EN pin to enable the device. If an application requires control of the EN pin, use open-drain or open-collector output logic to interface with the pin”
