Inquire TI P2P solution to replace MPS solution
Other Parts Discussed in Thread: TLV62569, TLV62084A
Hi Sir,
May I learn from you do we have P2P solution could replace MPS solution as below?
MP2161
MP2235
MP2234GJ-Z
MP1474D
MP1475
If not, could you kindly help to suggest the most suitable solution to compete with MPS?
Thank you for your kindly help.
Edward Chen
  • Hello Edward,
    Please use the Cross-Reference Tool to find this information: https://bomcross.ti.com/en/  .
    For example, MP2161 shows the following:
    You searched for:
    MP2161
    Cross reference parts for Monolithic Power Systems MP2161 (2)
    Select an equivalent TI cross reference part to see additional details.
    TI part number
    Cross reference code P F
    Datasheet
    Description
    Stock
    Priced from
    Part status
    Parametrics
    Parametric compare
    Select part
    TLV62569 P 2-A High Efficiency Step-down Buck Converter in SOT23 and SOT563 Package ACTIVE Compare TLV62569
    TLV62084A F 2A High Efficient Step Down Converter in 2x2mm SON Package ACTIVE Compare TLV62084A
    Hopefully you will find many that are Code'S' (pin-to-pin).
    ~Leonard
