Hello
- We would like to extract the fault logs from a master/slave UCD device pair which are only remotely accessible.
- We are able to export the configuration files of these UCD devices into Intel HEX format .
- Next, the configuration files are imported into some local UCD devices which are accessible in our own lab.
- During the TI Fusion Digital Power Designer Device Configuration Import step, when the Data Flash Import happens, the log reports that "Clearing data flash logs...".
- Therefore, all the fault logs stored in the configuration file, exported into the Intel HEX file, are lost when read back by the TI Fusion tool.
- Is it possible to disable the "Clearing data flash logs..." step in the import script of the TI Fusion Tool? Please advise.
Thank you and best regards, Peter.
