Other Parts Discussed in Thread: LM5050-1
Customer wants to know the leakage current from C(pin 10) to A(pin 11) on TPS2410.
Can you help to check and give some comments?
Thanks a lot.
Olive Ou
Hi Kari,
Please help to check the leakage current from C(Pin10) to A(Pin 11) on TPS2410 asap.
Customer also wants to know the leakage current from out to IN pin on LM5050. From 8.2.4 on datasheet, it would be 50uA right?
Can we add a 1K resistor from IN pin to Ground to clamp the voltage caused by the leakage current to 50mV?
or still need to consider more items for this reverse current?
Thanks.
Oliver Ou
2248.1031.TPS241x Leakage Path_Measurements.pdfHi
For leakage current of TPS2410 from C to A, refer to the attachment showing the measured values and the leakage path.
Kari.
Hi Kari,
Thanks a lot for your sharing.
For LM5050, the leakage should be 50uA as the datasheet described , is it right?
Oliver Ou
