Hi team,
I was observing the voltage ringing at the switch node by using the EVM. I found the voltage overshoot and ringing is different at different input voltages. In my opinion, the ringing at VIN=12V(left figure)is much more common and easier to understand. But when the input voltage is 24V or much higher, the ringing become less obvious. It seems that the switching speed of the top switch is much slower? How does this phenomenon happen? Could you please give some explanation?
Thanks.
