All cell conversion time is in 2.4ms on the datasheet P.1.
How can I calculate this time?
Kohei Sasaki
Kohei Sasaki
Taylor-san, Andy-san,
Thank you for your answer.
I understood your recommended setting.
Voltage reading accuracy becomes worse by following setting, right?
- Set CMD_OVS_CYCLE = 1
- Reduce ADC sample period
- Reduce oversampling times
Kohei Sasaki
Hi Kohei,
CMD_OVS_Cycle setting will impact sync between cells and overall conversion time for all channels;
OVS will not impact accuracy but noise suppression;
If out cap is 390nf, then use our recommended setting for period parameters.
Thanks!
Andy
Kohei,
390pf is our recommendation. If you use other values, it is your responsibility to validate it.
There are still some information in EVM user guide. You can check.
Thanks!
Andy
