BQ4050EVM-561: bqStudio (version 1.3.54.1) doesn't recognize my device
Part Number: BQ4050EVM-561
Other Parts Discussed in Thread: BQSTUDIO, BQ40Z50, BQ40Z50EVM-561, BQ40Z50-R2
I started bqStudio (version 1.3.54.1, the latest version), selected "Gauge", found both 4500_0_12-bq40z50 and 4500_1_06-bq40z50R1 in the list. But when selected, both gave a warning “The detected device is not compatible with this application! … Proceed at your own risk.”
after proceeding, both selections find bq40z50 and bq40z50R1 at
4500_2_08
Address: 0x17
23.2 degC
Two questions:
1.) What version of the chip is on my bq40z50EVM-561, the bq40z50 or the bq40z50R1?
2.) What do I need to do with bqStudio to be able to read and control my EVM?
Please let me know.
Carl Olen
  • 4500_2_08 indicates that you have the bq40z50-r2. It is an upgraded fw rev that uses the same hw IC. Please go to the bq40z50-r2 page to download the bqstudio from there.
  • Batt, I've been searching high and low on the bq40z50-r2 page and cannot find the link to download the bqstudio from there. Can you please send me the link to the specific bqStudio download that will work with my bq40z50-r2 device? What version of bqStudio am I looking for? The version v1.3.54.1 is the latest I could find and that was the one that didn't work.
    Carl
  • I apologize for the confusion. Please use the test version for bqstudio v1.3.86.3 available here, www.ti.com/.../BQSTUDIO.
  • Batt,
    So, I removed bqStudio v1.3.54.1 Build 1 and attempted to install in its place v1.3.86.3, per your suggestion from TI (for recognizing the bq40z50-r2). This is also known as “bqStudioTest.” This time, however, I’m going to completely uninstall the previous version before re-installing the new one.
     The funny thing is when I download and install this new version, it claims to be “bqSBB Version 1.3.90 Build 1”
    After installing this program, the bqStuio opens up and says: “Bqsbb: An error has occurred. See the log file C:\ti\BatteryManagementStudio\configuration\1559178478919.log.” I have attached a copy of this log file.  Right now I have no working version of bqStudio. Please help me understand what I need to do to get this working.
    Carl Olen
    !SESSION 2019-05-29 21:07:58.739 -----------------------------------------------
    eclipse.buildId=unknown
    java.version=1.8.0_74
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Framework arguments:  -clearPersistedState -persistState false
    Command-line arguments:  -os win32 -ws win32 -arch x86 -clearPersistedState -persistState false
    !ENTRY com.ti.evswsdk 4 0 2019-05-29 21:07:59.988
    !MESSAGE FrameworkEvent ERROR
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk [312]
      Unresolved requirement: Import-Package: com.ti.evswsdk.dashboard
        -> Export-Package: com.ti.evswsdk.dashboard; bundle-symbolic-name="com.ti.evswsdk.dashboard"; bundle-version="1.2.0.201904161239"; version="0.0.0"
           com.ti.evswsdk.dashboard [340]
             Unresolved requirement: Import-Package: com.ti.evswsdk.gpcpackager.views
    	at org.eclipse.osgi.container.Module.start(Module.java:434)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
    !ENTRY com.ti.evswsdk.authentication 4 0 2019-05-29 21:07:59.998
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.authentication [315]
    !ENTRY com.ti.evswsdk.calbq769x2 4 0 2019-05-29 21:07:59.998
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.calbq769x2 [321]
      Unresolved requirement: Import-Package: com.ti.evswsdk.programming769x2
        -> Export-Package: com.ti.evswsdk.programming769x2; bundle-symbolic-name="com.ti.evswsdk.programming769x2"; bundle-version="1.0.0.201904161239"; version="0.0.0"; uses:="org.osgi.framework,  org.eclipse.swt.graphics,  org.eclipse.jface.resource,  org.eclipse.swt.widgets,  org.eclipse.jface.dialogs,  org.eclipse.ui.plugin"
           com.ti.evswsdk.programming769x2 [374]
    !ENTRY com.ti.evswsdk.dashboard 4 0 2019-05-29 21:08:00.018
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dashboard [340]
    !ENTRY com.ti.evswsdk.dataflashview 4 0 2019-05-29 21:08:00.018
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.dataflashview [341]
      Unresolved requirement: Import-Package: com.ti.evswsdk.fsexport
        -> Export-Package: com.ti.evswsdk.fsexport; bundle-symbolic-name="com.ti.evswsdk.fsexport"; bundle-version="1.0.0.201904161239"; version="0.0.0"
           com.ti.evswsdk.fsexport [349]
    !ENTRY com.ti.evswsdk.fieldprogrammer 4 0 2019-05-29 21:08:00.018
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fieldprogrammer [347]
    !ENTRY com.ti.evswsdk.firmware 4 0 2019-05-29 21:08:00.028
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.firmware [348]
    !ENTRY com.ti.evswsdk.fsexport 4 0 2019-05-29 21:08:00.028
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.fsexport [349]
    !ENTRY com.ti.evswsdk.gdk 4 0 2019-05-29 21:08:00.028
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.gdk [351]
      Unresolved requirement: Import-Package: com.ti.evswsdk.dataflashview
        -> Export-Package: com.ti.evswsdk.dataflashview; bundle-symbolic-name="com.ti.evswsdk.dataflashview"; bundle-version="1.3.0.201904161239"; version="0.0.0"
    !ENTRY com.ti.evswsdk.goldenizing 4 0 2019-05-29 21:08:00.038
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.goldenizing [354]
    !ENTRY com.ti.evswsdk.programming769x2 4 0 2019-05-29 21:08:00.038
    !STACK 0
    org.osgi.framework.BundleException: Could not resolve module: com.ti.evswsdk.programming769x2 [374]
    !ENTRY com.ti.evswsdk.fieldprogrammer 2 0 2019-05-29 21:08:00.368
    !MESSAGE Could not resolve module: com.ti.evswsdk.fieldprogrammer [347]
    !ENTRY com.ti.evswsdk 2 0 2019-05-29 21:08:00.368
    !MESSAGE Could not resolve module: com.ti.evswsdk [312]
    !ENTRY com.ti.evswsdk.calbq769x2 2 0 2019-05-29 21:08:00.368
    !MESSAGE Could not resolve module: com.ti.evswsdk.calbq769x2 [321]
    !ENTRY com.ti.evswsdk.firmware 2 0 2019-05-29 21:08:00.378
    !MESSAGE Could not resolve module: com.ti.evswsdk.firmware [348]
    !ENTRY com.ti.evswsdk.dashboard 2 0 2019-05-29 21:08:00.378
    !MESSAGE Could not resolve module: com.ti.evswsdk.dashboard [340]
    !ENTRY com.ti.evswsdk.programming769x2 2 0 2019-05-29 21:08:00.378
    !MESSAGE Could not resolve module: com.ti.evswsdk.programming769x2 [374]
    !ENTRY com.ti.evswsdk.goldenizing 2 0 2019-05-29 21:08:00.388
    !MESSAGE Could not resolve module: com.ti.evswsdk.goldenizing [354]
    !ENTRY com.ti.evswsdk.gdk 2 0 2019-05-29 21:08:00.388
    !MESSAGE Could not resolve module: com.ti.evswsdk.gdk [351]
    !ENTRY com.ti.evswsdk.fsexport 2 0 2019-05-29 21:08:00.388
    !MESSAGE Could not resolve module: com.ti.evswsdk.fsexport [349]
    !ENTRY com.ti.evswsdk.dataflashview 2 0 2019-05-29 21:08:00.398
    !MESSAGE Could not resolve module: com.ti.evswsdk.dataflashview [341]
    !ENTRY com.ti.evswsdk.authentication 2 0 2019-05-29 21:08:00.398
    !MESSAGE Could not resolve module: com.ti.evswsdk.authentication [315]
    !ENTRY org.eclipse.osgi 4 0 2019-05-29 21:08:00.418
    !MESSAGE Application error
    !STACK 1
    java.lang.RuntimeException: Application "com.ti.evswsdk.evswsdk" could not be found in the registry. The applications available are: org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
    	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
    	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
  • Batt, okay.  I found the download for bqStudio v1.3.86_Build3.  I uninstalled the other version and installed this on, and it recognizes my gauge bq40z50-r2.
    This resolves my issue.
    Carl Olen
