Hi, Team.
This is MASA.
i've been asked by Customer below.
How our IC behaviors and outputs in case of thermal shutdown and current limit?
there is no description about thermal shutdown.
but its datasheet shows block diagram that has thermal shutdown is connected with logic with Gate for FET.
i assume that Device is going to turn off (no switching) in case of thermal shutdown, correct ?
what about current limit?
in case of current limit, what kind of output does device do?
does the device switching off ?(does it mean not foldback output ?which means device can't handle its load current to be small current right?)
it would be nice if you could help.
