Hi dear Ti community.
At this moment I'm working on my PSU and I've got few concerns about it - details below :
I'm going to use MeanWell MPM-30-24 module (or IRM-30-24) as my main PSU, but I'm looking for good solution to lower it output voltage via step down IC (because this PSU couldn't be regulated).
So PSU is 1.3A - 24VDC, switching freq is ~ 65kHz.
What I want to achieve? Good and stable 18-20V output with ability to use all available current from this PSU.
There is a plenty of IC (according to Ti Power Designer) and I know some older types like LM2676.
My questions are :
- which one should I pick? Costs are my second concern here, my frist priority is to get stable and reliable output - I'm want to stick with converters or whole module instead of controllers,
- CLC input filter - should I use it? If yes how to calculate parts according to MeanWell PSU spec (if this is somehow important),
- LC output filter (post filter) does it really matter if I'm going to use hi-PSRR voltage regulators right after those DC-DC?
- I assume if I pick buck IC with swithing freq in range of best PSRR performance of my LDO I'll make best deal?
Thank you for your time ;)
If you need more info or clarification just tell me what you need, I'll try to answer best I could.
