Had a query on how the output varies with variation in surrounding temperature. Any characteristic curve or tabulation would be helpful. the surrounding temperature varies over the full range as per the recommendations
Hi Aishwarya:
You could calculate the Vout target base the FB voltage and the divided resistance design. And the Vfb range/accuracy is listed in the datasheet 7.5.
May I know what's your Vin range, Vout, and the load condition? And what mode you want to choose?(PFM or FPWM). These factors all will influence the Vout in some case.
Hi Aishwarya:
Is there anything updated? I closed the thread assuming that you had solved the issue. if not, just reply below. Thank you·~
Hi Aishwarya:
I found you reopen this post. May you update some information? Or it's hard for us to give you suggestions/answers. Thanks for your kindly understanding.
Hi Aishwarya:
I'll close this post as we couldn't hear from you. If you have any further question, just reply below. Thanks for your understanding.
