Can you please share the layout guidelines for the SEPIC converter using LM3481
HI Ujwal,
Thank you for considering the LM3481 for your SEPIC design. The layout should follow the regular SEPIC converter PCB design. Please watch the following video:
Or the article:
https://www.eetimes.com/author.asp?section_id=36&doc_id=1329265#
addressing the layout tips.
Youhao Xi, Applications Engineering
Hi Ujwal,
The layout stratigies mentioned above can be applied to a SEPIC with two discrete inductors. The basic concepts are still the same in regards to keeping the high di/dt current loops small. There is more flexibility to do this as the inductors are discrete.
Garrett
