LM25118: Negative output
Part Number: LM25118
Other Parts Discussed in Thread: LM5155
Hi team,
Does LM25118 support negative output? How to change the circuit?
Thanks very much!
Miranda
  • Hi Miranda,
    For positive to negative conversion, the LM25118 is not a right choice. A right part is either a buck controller in inverting buck-boost configuration, or boost controller for an inverting sepic, or flyback,  and the right engineer will answer you. Please post with a part number (buck or boost), You need to tell the specs in order to get appropriate proposals from BU.
    Youhao Xi, Applications Engineering
  • Hi Youhao,
    The input is 3.3V, output is -8 ~ -1.23V/5A. Do you have any recommendation? Thank you!
    Miranda
  • Hi Miranda,
    You may consider the LM5155 in a inverting SEPIC.  If further support needed, you can reach to a TI sales representative or FAE  in your region, and ask for a reference design from TI Reference Design group.
    Youhao
