Hi team
My customer want to change the IC from RT8237FGQW to TPS53119RGTR.
I want to change the IC that is applied to Intel CPU EVM.
Is there a problem when I change it?
Thank you.
Hi team
Thank you.
Charles,
You can conceivably change to TPS53119, the device applications are similar. TPS53119 is not pin compatible with RT8237FGQW, so there is some re-design to consider. Let me know if you have further questions.
