Part Number: BQ27Z561-R1
Hi team,
May I know the minimum resistance value of BQ27Z561-R1 I2C pull-up resistors?
Customer want to use 1kohm to decrease power loss. Baud rate is 400kHz and voltage is 1.8V. Could you give some comments?
Miranda
Hi team,
Miranda
hi Miranda
The external pull-up devices connected to the bus lines must be adapted to accommodate the shorter maximum permissible rise time for the I2C-bus. pls see the i2c spec and data sheet of the device for the rise times.
I have attached an app no on sizing the resistor of i2 c devices.0841.calculating the pull_ups for i2c lines.pdf
thanks
Onyx
Hello Onyx,
What is the value of Cb and IOL? I cannot find them in datasheet.
Miranda
