Other Parts Discussed in Thread: TPS65235
Could you please tell me DiSEqC protocol ?
Q1.
Can TPS65235-1 convert I2C data to 22kHz tone signal and convert 22kHz tone signal to I2C data if transmitting and receiving with DiSEqC 2.x ?
Q2.
Can TPS65235-1 receive 22kHz tone signal via DIN pin(15 pin) ?
Q3.
Please tell me the recommended setting procedure for TPS65235-1 in detail if receiving DiSEqC1.x signal and performing LNB settings.
Q4.
I refer the following application note, so please let me know if there is a document that mentions the basic contents of DiSEqC.
DiSEqC Protocol and Low-Noise Block Voltage Regulator TPS65235 for Satellite - STB/TV
http://www.ti.com/lit/an/slva863/slva863.pdf
Kato
