Other Parts Discussed in Thread: TPS92691
dear sir,
this TPS92691 ic pwm pin current rating.what is the maximum current rating.?
dear sir,
Hi Sudarsh,
PWM (pin 4) is an input to our part and the input impedance is 1 Meg Ohm and the specification for this pin is on page 6 of the data sheet.
Thanks Tuan
Hi Sudarsh,
I do not fully understand your question here. I'll try to explain the DDRV output for you.
DDRV is the series dimming FET gate driver output that can connect directly to a external NFET for series dimming on the lo side or level shifted to drive a PFET for high side PWM'ing. Please section 7.3.8 for more explanation on this along with figure 22.
Thanks Tuan
Hi Sudarsh,
Please send a schematic to us for what you are trying to do. I still do not fully understand your question here.
Thanks Tuan
Hi Sudarsh,
We have not heard back from you so we believe you have solve you issue. The post will close now but reopen if you reply to it.
Thanks Tuan
