BQ24610: BQ24610
Part Number: BQ24610
In BQ24610, there is one timer option. With TTC pin we can set the charge current safety time.
What I understood from the datasheet is, with this pin we can set charging time and after this it will disable the charging.
My understanding is correct or not?
I just want to know whether the IC will monitor the battery voltage?
without timer option whether the IC will disable the charging when the battery is full by monitoring the voltage ?
Shafeeq
