Other Parts Discussed in Thread: CDCLVC1103
I am considering using TPS54560B with the synchronization mode, so if the clock source cannot drive 50ohm termination resistor, how should this issue be solved ?
Kato
Kato
Hi Kato-san,
Would you be able to use a buffer in order to drive the 50 ohm load?
-Arief
Hi Arief-san,
Thank you for your prompt reply.
I would like to use the low cost clock buffer such as CDCLVC1103. Therefore, please tell me how to use the termination resistor more than 50Ω if possible.
Kato
Hi Arief-san,
Sorry for rushing you, but please let me know if you have any updates on this.
Kato
Hi Kato-san,
What RT that you are planning to use?
If you are going to synchronize it at all time, then with this clock buffer should be able to drive a 1kohm resistor
-Arief
Hi Arief-san,
Thank you for the information.
I will try using tbe synchronization mode with 1kohm resistor.
Kato
