BQ27542-G1: bq27542-g1
Part Number: BQ27542-G1
WHAT IS THE MAXIMUM AND MINIMUM RANGE OF THESE PARAMETERS ?
Command Unit Min Value Max Value
Control()
AtRate() mA
UnfilteredSOC() %
Temperature() 0.1oK
Voltage() mV
Flags() nil
NomAvailableCapacity() mAh
FullAvailableCapacity() mAh
RemainingCapacity() mAh
FullChargeCapacity() mAh
AverageCurrent() mA
TimeToEmpty() min
FullChargeCapacityFiltered() mAh
SafetyStatus() nil
FullChargeCapacityUnfiltered() mAh
Imax() mA
RemainingCapacityUnfiltered() mAh
RemainingCapacityFiltered() mAh
BTPSOC1Set() mAh
BTPSOC1Clear() mAh
InternalTemperature() 0.1oK
CycleCount() counts 0 65535
StateofCharge() %
StateofHealth() %/num
ChargingVoltage() mV 4000 4600
ChargingCurrent) mA
PassedCharge()
DOD0()
SelfDischargeCurrent()
what is the maximum and minimum range of these parameters in bq27542=g1 ?
