TPS23750EVM-108: How to get hold of the eval board mentioned in SLUA469
Part Number: TPS23750EVM-108
In SLUA469 it is discussed how to fight down conducted emissions by adding a CM choke (Pulse PE-53913NL). However, the referred eval board (TPS23750EVM-108) does not look the same as the one discussed in SLUA469. I do not see any CM choke L2 used. Where to by an eval board that is mentioned in SLUA469?
    Thank you for your question. The board mentioned in SLUA469 was built internally for testing and verification of EMC compliance. This board was not built to be shippable or orderable and so we are unable to provide you with the physical board. However, I recommend ordering the TPS23750EVM-108 and then modifying the board to add the necessary components as outlined in SLUA469 as a first step.
    Thank you very much for your time and please feel free to let me know if you have any other questions.
    Brett
