Other Parts Discussed in Thread: TPS65400
1>. if no I2C control, default only one PGOOD output? so can't use PGOOD to control power up sequence
2>. when VIN=12V, VO=1V, what is the highest Fsw? when i set one of outputs to 0.9V, webench set the fsw as 1MHZ, but your TON min is 150ns.
3>. how to calculate the compensation parts? any documents?
4>. if no I2C controller, need sequence control, any special attention?
