hi Team,
customer aware of the bq76pl455A there is BIST feature
build in self test, however, there is Test configuration TSTconfig 0x1E-0x1F (7.6.3.15)
but where to check the test result/status after the setting?
hi Team,
Hello John,
You can find most of the answer from DS by yourself.
LDO_TEST: I will give comments on this after I check with team;
CCNT_RST_OFF: If you set CTO and then enable this mode, finally chip will go into shutdown and you can detect;
VDIG_TEST: it is used to test short of NPN;
EQ_SQUEEZE_EN: it can be used for open wire detection;
(2) and (4) are result after ADC conversion.
Andy
Thanks Andy, but we were trying to ask, is there registers to check the test results/status of those items? where does the user check for the test results? Thanks
Hello John,
For some test, we can get result from some bits;
For some test, host should do further work and then can get result.
If engineers really start to design project, they should know where should they get results.
Thanks!
Andy
