Do you have data about the switchover time it takes LM5116 to switch from VCC to VCCX supply?
And a plot showing VCCx during the event of switchover when using a resistor from Vout to VCCX pin?
I have a case in which an LDO is used for VCCX supply and LM5116 is toggling between VCC and VCCX supply preventing proper output regulation. With higher capacitance at VCCX (= LDO output), situation improves but need to verify the design is sufficient robust.
Thanks & BR,
KF
