Hi
we are using BQ24780S smart Charger IC for charging the Li-ion Smart Battery. When the battery is connected to Charger IC through EV2300(SM Bus) Communication the battery is able to charge on its own(i.e able to charge through battery voltage and battery current). During charging the battery indicator and meter shows the charging when we click the Refresh or scan button then only we are able to get the charge voltage and current value on the window.
My question is that during refreshing or scanning only the Parameters Value will change?? until then it will be same as Default Values.
Kindly Do the needful.
