TPS65218D0: TPS65218D0 re^programming
Part Number: TPS65218D0
Other Parts Discussed in Thread: BOOSTXL-TPS65218,
When TPS65218Do is re-programmed by using BOOSTXL-TPS65218 EVM,
How many times can TPS65218DO be rewritten?
Best regards.,
Mitsuharu Iwasaki
  • Iwasaki-san,
    TPS65218D0 uses proprietary TI EEPROM
    Maximum R/W endurance = 1000 cycles.
    Typically, you only need to re-program each IC one time to use it in a specific application. However, if you plan on re-programming the device many times, then the maximum number of R/W cycles to the EEPROM is 1000.
