Other Parts Discussed in Thread: BQSTUDIO, BQ40Z50-R2
I plan to work with bq40z50-R3 and downloaded the newest version of bqStudio (1.3.86).
Here, I can only chose bq40z50-R2 and import its default values. I know that most values are same with R2 and R3 as well as the datasheet, but some new features are implemented as can be seen in the change list.
Is there any possibility to get default values for bq40z50-R3 imported or already select this bq-version in the startup of the program?
Or do you recommend just working with bq40z50-R2 selected in bqStudio?
Thank you in advance!
