I have some questions on the TPS3828Q1's SPEC.
my select Part.NO as below red box.
I need RESET Open-drain status, as below, it means WDI pin floating?
thanks.
thanks.
The device comparison table you are looking at is simply telling you if that product has a WDI pin or a MR pin. The TPS3828-Q1 contains both of these. If you are not using WDI, you should have this pin connected to high impedance to avoid a faulty reset.
Abhinav.
Thanks for your feedback.
I saw datasheet as below:
It's means if i don't need WDI function, connect 1kohm to GND, this WDI pin is disable?
thanks,
Your understanding is correct, you should disconnect WDI and if you are ok with the self-generated WDI pulse, leave it open, or else connnect it from WDI to GND.
Abhinav.
