TPS659037: LDO input Power
Part Number: TPS659037
Even if a power supply different from the 5V supplied to VSYS (VCC1) is input to LDO 34_IN, LDO 9_IN, and LDOLN_IN of PMIC (TPS6590379) (for example, a 2.5V power supply generated by a power IC different from PMIC), Is there not a problem?
We are considering a configuration to reduce loss and heat generation by LDO.
Shigehiro Tsuda
