Other Parts Discussed in Thread: EV2400, BQ34Z100, BQ40Z80, BQ27520-G4
Hi Team,
The customer does not want to use the EV2400+BqStdio to calibrate the BQ34Z100-G1. Instead, he wants to write the MCU program to calibrate the voltage, current and temperature of the BQ34Z100-G1. But the datasheet only writes the relevant commands for how to enter the calibration mode, and does not write how to calibrate the voltage,current and the temperature after entering. Also it does not write to which register the data to be calibrated should be written to. And what is the conversion relationship between the written data and the actual data, etc?
Is there any relevant information, or sample code?
Thanks.
