Other Parts Discussed in Thread: TPS2596
Hi team,
My customer plan to set the Ilimit to 500mA.
The customer would like to know how the device behave if current limit is less than minimum current limit when caused resistor value error.
Maximum recommended resistor value is 5000 ohm. I think it behave correctly when the resistor value is less than 5000 ohm, but if resistor value is higher than 5000 ohm, the device may not work correctly.
Could you please check this?
Yoshi
