Dear Sir,
Customer would know BQ24172RGYR Pd(max).
Please you kindly share information.
Thanks!
Steven
Dear Sir,
Thanks!
Steven
Hi Steven,
The BQ24172 has as thermal regulation circuit that clamps the output power when the junction temperature, Tj, = 120 C typical. Assuming the PCB has the same design as that used to compute the RthetaJA value in datasheet section 8.4, the max power dissipation is Pd(max) = (Tjmax-Ta_ / (RthethaJA) = (120 C - Ta)/(35.7C/W). If your customer's board design and airflow are not similar to those used to compute the datasheet's RthetaJA (see http://www.ti.com/lit/an/spra953c/spra953c.pdf) then the max power dissipation could be significantly different.
Jeff
