BQ24715: bq24715 could not stop charge because charge current unstable
Part Number: BQ24715
Other Parts Discussed in Thread: BQ30Z50,
Hi
our new project use bq24715 charge 2S battery use BQ30Z50 for battery manager ic.
sometimes could not full charge ,because the charge current is unstable between 100mA~500mA when charge to 99%,
our stop  charge  current is 200mA, the F/R=1/100, and this issue only happpen at first time or second time in our NB.
could you please support some metherd debug this issue.
the attach file is the charge log when issue happen. the battery gauge team  think must change the bq24715 setting solve this issue.
wanglin 18664983545
                                    Cells Voltage (mV)
Start time : 2018-04-20 07:33:06
        time         cur(mA)    vol(mV)   cap(mAh)  percent(%)
04-20 07:33:11        108       8716      46056       99
04-20 07:33:16         92       8675      46056       99
04-20 07:33:21         20       8680      46056       99
04-20 07:33:26        112       8664      46048       99
04-20 07:33:31        266       8682      46048       99
04-20 07:33:36         24       8696      46048       99
04-20 07:33:41        174       8697      46048       99
04-20 07:33:46        107       8684      46048       99
04-20 07:33:51        131       8705      46048       99
04-20 07:33:56        250       8720      46048       99
04-20 07:34:01        322       8723      46048       99
04-20 07:34:06         84       8710      46048       99
04-20 07:34:11         50       8711      46048       99
04-20 07:34:16         25       8681      46048       99
04-20 07:34:21        120       8675      46056       99
04-20 07:34:26         63       8712      46056       99
04-20 07:34:31        315       8729      46056       99
04-20 07:34:36         38       8721      46056       99
04-20 07:34:41         20       8709      46071       99
04-20 07:34:46        273       8727      46071       99
04-20 07:34:51        302       8731      46071       99
04-20 07:34:56         25       8714      46071       99
04-20 07:35:01        302       8728      46086       99
04-20 07:35:06        294       8730      46086       99
04-20 07:35:11         82       8698      46086       99
04-20 07:35:16        300       8728      46086       99
04-20 07:35:21        303       8727      46086       99
04-20 07:35:26        227       8728      46086       99
04-20 07:35:31        226       8726      46086       99
04-20 07:35:36        111       8723      46086       99
04-20 07:35:41        154       8684      46086       99
04-20 07:35:46        145       8695      46086       99
04-20 07:35:51         10       8712      46094       99
04-20 07:35:56         73       8706      46094       99
04-20 07:36:01        103       8704      46094       99
04-20 07:36:06        301       8729      46094       99
04-20 07:36:11        110       8678      46094       99
04-20 07:36:16         14       8708      46094       99
04-20 07:36:21        298       8729      46094       99
04-20 07:36:26        102       8714      46094       99
04-20 07:36:31        111       8686      46109       99
04-20 07:36:36        107       8689      46109       99
04-20 07:36:41         30       8709      46109       99
04-20 07:36:46        214       8725      46109       99
04-20 07:36:51        295       8725      46109       99
04-20 07:36:56        289       8731      46109       99
04-20 07:37:01        284       8731      46109       99
04-20 07:37:06         63       8716      46109       99
04-20 07:37:11        285       8730      46117       99
04-20 07:37:16        145       8687      46117       99
04-20 07:37:21        232       8682      46117       99
04-20 07:37:26        134       8729      46117       99
04-20 07:37:31        243       8729      46117       99
04-20 07:37:36         94       8714      46117       99
04-20 07:37:41         66       8695      46117       99
04-20 07:37:46        153       8693      46117       99
04-20 07:37:51         25       8710      46117       99
04-20 07:37:56        107       8687      46117       99
04-20 07:38:01        297       8729      46117       99
04-20 07:38:06        296       8728      46117       99
04-20 07:38:11        288       8730      46132       99
04-20 07:38:16         97       8696      46132       99
04-20 07:38:21         42       8701      46132       99
04-20 07:38:26         63       8714      46132       99
04-20 07:38:31        283       8729      46132       99
04-20 07:38:36        210       8719      46132       99
04-20 07:38:41        190       8721      46132       99
04-20 07:38:46        154       8687      46147       99
04-20 07:38:51          0       8709      46147       99
04-20 07:38:56        282       8729      46147       99
04-20 07:39:01        279       8731      46147       99
04-20 07:39:06        144       8730      46147       99
04-20 07:39:11        218       8729      46147       99
04-20 07:39:16        213       8721      46147       99
04-20 07:39:21        127       8725      46147       99
04-20 07:39:26        115       8699      46147       99
04-20 07:39:31        136       8719      46147       99
04-20 07:39:36        147       8682      46147       99
04-20 07:39:41        278       8730      46147       99
04-20 07:39:46         31       8714      46147       99
04-20 07:39:51        276       8729      46147       99
04-20 07:39:56        183       8725      46162       99
04-20 07:40:01        169       8681      46162       99
04-20 07:40:06         28       8724      46162       99
04-20 07:40:11        180       8684      46162       99
04-20 07:40:16         12       8726      46162       99
04-20 07:40:21        216       8699      46162       99
04-20 07:40:26        211       8704      46162       99
04-20 07:40:31        216       8697      46147       99
04-20 07:40:36        228       8724      46147       99
04-20 07:40:41         21       8712      46162       99
04-20 07:40:46         75       8712      46162       99
04-20 07:40:51        172       8727      46162       99
04-20 07:40:56        190       8732      46162       99
04-20 07:41:01        227       8707      46162       99
04-20 07:41:06        282       8728      46162       99
04-20 07:41:11         35       8698      46162       99
04-20 07:41:16        132       8729      46178       99
04-20 07:41:21        123       8731      46178       99
04-20 07:41:26         47       8714      46178       99
04-20 07:41:31        279       8731      46178       99
04-20 07:41:36        275       8732      46178       99
04-20 07:41:41         68       8712      46178       99
04-20 07:41:46        146       8702      46178       99
04-20 07:41:51         43       8710      46178       99
04-20 07:41:56        281       8731      46178       99
04-20 07:42:01        266       8726      46178       99
04-20 07:42:06         57       8715      46178       99
04-20 07:42:11        168       8687      46185       99
04-20 07:42:16         30       8700      46185       99
04-20 07:42:21         57       8725      46185       99
04-20 07:42:26          9       8724      46185       99
04-20 07:42:31         37       8712      46185       99
04-20 07:42:36         76       8695      46185       99
04-20 07:42:41        218       8726      46185       99
04-20 07:42:46        159       8729      46185       99
04-20 07:42:51        276       8731      46185       99
04-20 07:42:56         27       8719      46185       99
04-20 07:43:01        147       8709      46185       99
04-20 07:43:06        105       8703      46185       99
04-20 07:43:11        169       8696      46185       99
04-20 07:43:16        137       8728      46185       99
04-20 07:43:21        207       8730      46185       99
04-20 07:43:26        180       8690      46185       99
04-20 07:43:31         44       8706      46208       99
04-20 07:43:36        207       8732      46208       99
04-20 07:43:41        234       8701      46208       99
04-20 07:43:46        206       8731      46208       99
04-20 07:43:51        267       8710      46208       99
04-20 07:43:56        211       8701      46208       99
04-20 07:44:01        272       8729      46208       99
04-20 07:44:06        100       8702      46208       99
04-20 07:44:11        131       8691      46208       99
04-20 07:44:16        133       8729      46208       99
04-20 07:44:21        161       8724      46208       99
04-20 07:44:26        117       8711      46208       99
04-20 07:44:31         61       8703      46208       99
04-20 07:44:36        120       8699      46208       99
04-20 07:44:41        168       8725      46208       99
04-20 07:44:46         55       8701      46208       99
04-20 07:44:51         41       8707      46208       99
04-20 07:44:56         70       8713      46208       99
04-20 07:45:01        131       8689      46208       99
04-20 07:45:06         39       8716      46208       99
04-20 07:45:11        264       8684      46208       99
04-20 07:45:16        276       8728      46208       99
04-20 07:45:21         71       8730      46208       99
04-20 07:45:26        208       8733      46223       99
04-20 07:45:31        204       8731      46223       99
04-20 07:45:36         40       8703      46223       99
04-20 07:45:41         41       8702      46223       99
04-20 07:45:46        270       8731      46223       99
04-20 07:45:51        204       8731      46223       99
04-20 07:45:56         55       8707      46223       99
04-20 07:46:01         36       8704      46223       99
04-20 07:46:06         39       8706      46223       99
04-20 07:46:11        104       8713      46223       99
04-20 07:46:16        106       8709      46223       99
04-20 07:46:21        197       8727      46223       99
04-20 07:46:26        279       8731      46223       99
04-20 07:46:31        234       8697      46223       99
04-20 07:46:36        247       8699      46223       99
04-20 07:46:41         33       8711      46223       99
04-20 07:46:46        278       8725      46223       99
04-20 07:46:51        140       8733      46223       99
04-20 07:46:56        172       8705      46223       99
04-20 07:47:01        116       8733      46223       99
04-20 07:47:06        140       8718      46223       99
04-20 07:47:11         82       8682      46238       99
04-20 07:47:16        138       8709      46238       99
04-20 07:47:21        210       8727      46223       99
04-20 07:47:26        112       8695      46223       99
04-20 07:47:31        285       8729      46223       99
04-20 07:47:36         93       8714      46223       99
04-20 07:47:41        284       8728      46223       99
04-20 07:47:46        121       8700      46223       99
04-20 07:47:51        113       8714      46223       99
04-20 07:47:56         88       8721      46223       99
04-20 07:48:01         98       8714      46223       99
04-20 07:48:06        139       8703      46223       99
04-20 07:48:11        108       8687      46223       99
04-20 07:48:16        144       8689      46223       99
04-20 07:48:21        215       8730      46208       99
04-20 07:48:26        207       8732      46208       99
04-20 07:48:31         45       8692      46208       99
04-20 07:48:36         60       8721      46208       99
04-20 07:48:41        283       8731      46223       99
04-20 07:48:46         99       8716      46223       99
04-20 07:48:51        250       8725      46223       99
04-20 07:48:56         74       8697      46223       99
04-20 07:49:01        172       8688      46223       99
04-20 07:49:06         27       8696      46223       99
04-20 07:49:11         48       8709      46208       99
04-20 07:49:17         89       8714      46208       99
04-20 07:49:22        213       8726      46208       99
04-20 07:49:27        115       8727      46223       99
04-20 07:49:32        195       8727      46223       99
04-20 07:49:37        115       8691      46223       99
04-20 07:49:42        112       8696      46223       99
04-20 07:49:47        193       8698      46223       99
04-20 07:49:52        127       8712      46223       99
04-20 07:49:57        283       8730      46223       99
04-20 07:50:02         27       8726      46223       99
04-20 07:50:07        114       8732      46223       99
04-20 07:50:12        133       8692      46223       99
04-20 07:50:17         60       8722      46223       99
04-20 07:50:22        128       8692      46223       99
04-20 07:50:27        104       8703      46238       99
04-20 07:50:32        125       8693      46238       99
04-20 07:50:37        198       8729      46238       99
04-20 07:50:42        119       8693      46238       99
04-20 07:50:47         40       8700      46238       99
04-20 07:50:52        213       8722      46238       99
04-20 07:50:57        211       8692      46238       99
04-20 07:51:02        193       8721      46238       99
04-20 07:51:07         16       8717      46238       99
04-20 07:51:12         72       8720      46238       99
04-20 07:51:17         20       8723      46238       99
04-20 07:51:22        204       8730      46261       99
04-20 07:51:27        189       8724      46261       99
04-20 07:51:32         94       8711      46261       99
04-20 07:51:37        258       8734      46261       99
04-20 07:51:42         42       8717      46261       99
04-20 07:51:47        132       8692      46261       99
04-20 07:51:52        274       8730      46261       99
04-20 07:51:57        197       8732      46261       99
04-20 07:52:02        125       8724      46261       99
04-20 07:52:07        261       8732      46261       99
04-20 07:52:12        178       8713      46276       99
04-20 07:52:17        172       8690      46276       99
04-20 07:52:22        210       8697      46261       99
04-20 07:52:27         55       8695      46261       99
04-20 07:52:32         33       8706      46261       99
04-20 07:52:37        218       8693      46261       99
04-20 07:52:42        154       8721      46238       99
04-20 07:52:47         82       8707      46238       99
04-20 07:52:52        284       8682      46238       99
04-20 07:52:57        271       8682      46238       99
04-20 07:53:02        273       8700      46238       99
04-20 07:53:07        310       8679      46238       99
04-20 07:53:12         43       8708      46238       99
04-20 07:53:17        271       8685      46238       99
04-20 07:53:22        267       8680      46238       99
04-20 07:53:27        250       8722      46185       99
04-20 07:53:32          0       8721      46185       99
04-20 07:53:37         90       8698      46185       99
04-20 07:53:42        328       8684      46185       99
04-20 07:53:47        319       8681      46185       99
04-20 07:53:52         48       8698      46178       99
04-20 07:53:57        163       8719      46178       99
04-20 07:54:02         29       8725      46178       99
04-20 07:54:07         12       8682      46178       99
04-20 07:54:12        187       8684      46178       99
04-20 07:54:17        101       8681      46178       99
04-20 07:54:22        166       8729      46178       99
04-20 07:54:27         71       8713      46178       99
04-20 07:54:32         88       8723      46178       99
04-20 07:54:37        293       8730      46178       99
04-20 07:54:42        296       8697      46178       99
04-20 07:54:47         44       8688      46185       99
04-20 07:54:52        282       8730      46185       99
04-20 07:54:57        214       8729      46185       99
04-20 07:55:02         54       8710      46185       99
04-20 07:55:07        164       8727      46185       99
04-20 07:55:12         22       8714      46185       99
04-20 07:55:17         42       8720      46185       99
04-20 07:55:22         58       8690      46185       99
04-20 07:55:27        279       8730      46185       99
04-20 07:55:32         36       8711      46208       99
04-20 07:55:37        218       8721      46208       99
04-20 07:55:42        428       8674      46208       99
