LM3639A: Output current per series
Part Number: LM3639A
Hello
              For LCD Backlight Driver, what is maximum current for every series on 10S2P? Thank you.
BR
Patrick
  • Hi Patrick,
         For LED driver, the output current is not only controlled by the current sink, it is also controlled by the input voltage, current limit and output LED voltage.  Here is FAQ link that I posted before to estimate hou much current for a led driver, you can use this method to estimate the maximum output current for a dedicate devices:
    Sean
